Connecting Cameras to PC
questkid44
535
Hi,
I was wondering if there was a way that i could connect 12 cameras that use the BNC camera to a surveillance server, and if you could recommend a software that could take advantage of up to 16 channels. Thanks!!
It would almost certainly be easier and cheaper to purchase a dedicated setup
Comes with 16 cameras and the monitor
https://www.lorextechnology.com/site/complete-surveillance-system/Complete-16-camera-security-system-with-monitor/1855.p
or this: http://www.amazon.com/Samsung-SDS-P5080N-Channel-Security-Cameras/dp/B00D8FV9MM
Comes with 8, connections for 16 cameras.
To connect to an existing server? You'd need 3-4 PCI-E cards (4 connections each)
That motherboard only has 1 PCI-E slot.
So you'd be limited to 1 card (4 BNC camera ports).
Software? What does the card manufacturer recommend?
