It might help if you told us what end result you want. Do you want to make a wired connection to a PC? Connect 4 wifi PCs onto the school's network? What?
Does the uni have a support department that will help you?
_______________
+1 School should have a tech dept to help, if of course this is allowed and can be done legally.
Yes, I am trying to connect my PC to the school network. And since I am only staying for the summer the IT department locked the ethernet ports so I can only use the wifi.
