Hi,
I’m actually going to build my first PC.
ASUS Maximus VII Hero
I7-4790k
Corsair H110 for Cooling
My questions is about how to connect the Corsair H110 as well as the 2 Fan’s to be handled in PWM by the same Connection to the Motherboards CPU Header.
I bought already a specific Evercool ED-DF001 PWM Splitter cable and thought about connecting the Pump to the 4PIN PWM Connector and the 2 FAN’s, to 2 of the 4, 3 PIN connectors and all together connected to the CPU Connector on the Motherboard. The Idea is that the Pump Speed aswell as the Fans are increasing/decreasing there speed in relation with the CPU temperature.
When I look however to the 3 PIN connections of the Splitter, than I see that they have 2 pins, on free place and again 1 Pin. (1Pin ; 1Pin ; Free ; 1Pin)
This would mean that if I connect my 3 PIN fan’s (1Pin ; 1Pin ; 1Pin) to this connector, only 2 of the 3 PIN’s of the fan’s would get connected (Pin 1+2 or Pin 1+3, depending how they will be inserted).
I’m a bit confused and I hope that you can help me or give me some more information/advise to better setup the way the Computer will be cooled.
The Case is a Corsair Obsidian 750D that comes already with 3 140mm 3Pin Fans.
On top of these 3 Fan’s, I will have the 2 Fans of the Corsair H110 Water cooler and a Corsair Vengeance RAM Cooler.
The Motherboard has 6 Fan connectors and I thought connect them like this.
CPU1 (Water cooler+2Fan’s)
CPU2 (Corsair Vengeance Fan)
Case Fan 1 (Case Fan 1 from front)
Case Fan 2 (Case Fan 2 from Front)
Case Fan 3 (Case Fan from Back)
Case Fan 4 (reserve for an AF120 Fan on the bottom once the filters arrived)
I7-4790k
