Hello everyone, I have used dell optiplex 7010 laying around with i5-3470 and thought I could put it to good use and make it a secondary gaming pc.
I've replaced its case (from SFF to a bigger one). Also have a better PSU and gonna buy used GPU, because right now it has none.
While chaning cases I thought I'll try to change CPU cooler from default which was already in dell to an intel stock which I had laying around and collecting dust.
Problem was that fan pins where covered with plastic so intel would not fit in there..
I've removed plastic around pins (mistake?) and tried connecting intel's cooler. It did not work straight away. After playing around for a bit with how to connect it seemed to work, but after a while it just stopped (maybe I broke it.. have not tested it on different machine).
The issue is that now when I try to connect default cooler to those pins (CPU_FAN) it always spins at 4,5k rpms. I know it's not a fan's problem because I've also tried to connect case fan to it (came with same dell and has same connectors) and it too spins at 4,000+ rpm.
I came with a solution I've connected CPU fan into case fan pins and it spins at around 1k rpm.
My question would be is it possilbe to leave it like that? (speed fan shows normal temperatures)
Another question would be is it possible to fix CPU_FAN slot? If it is really faulty.
p.s dell's bios does not have fan control options to change it speed. It only has one option to make it run at full speed which is disabled.
Going to watch this thread. I hope someone can help me or suggest something. If not - have a great laugh and a great day
