Connecting hdmi cord into a rca cable ends.
I was pretty sure it's a bad idea. Just in case, I checked the forum for similar inquiries. Guess what: http://www.tomsguide.com/answers/id-3556833/wire-hdmi-cable-rca-cable.html The guy even provided the same link LOL. Sorry bro, but you're out of luck here it seems ;-)
You want a powered one though. So don't just get the cheapest one that might not work. This here is a powered one. Please note that I haven't tested this if it works. Read reviews before you buy. Good luck https://www.amazon.com/Musou-Composite-Converter-Support-Chromecast/dp/B015H76TRI/ref=sr_1_1_sspa?s=electronics&ie=UTF8&qid=1538454327&sr=1-1-spons&keywords=hdmi+to+rca+converter&psc=1
You don't. Completely different cables. HDMI is digital, RCA is analog. Aside from the fact there is much more inside an HDMI wire than the 2 wires inside an RCA.
What are you trying to connect from and to?
It clearly says "Mini HDMI" on the page I posted initially. Look at it again. Well.. if you didn't see it either, I don't feel so bad anymore LOL. Unless of course what they really meant was "Musou Mini" - HDMI. But I suspect it's actually Mini HDMI. No, I didn't edit it, that would be rather redundant. Yes it has an older mini-USB port on the side for power, but that's not what I was referring to.
