connecting HDMI internal cable wire to VGA socket
Bob Parihar
11
I have accediently pulled the soldered wire from the VGA socket Pins. now i want to re-solder the wires to the socket terminels.
the other end of HDMI cable has
6- white wires
3- red wires
2- blue wires
1-green wire
1- orange wire
the VGA socket contains 13 pins also but i dont know which wire can be soldered to which pin
somebody help please
I see.
The problem is that you need the spec sheet for the converter unit. I'm assuming you pulled more than one wire so things are a bit mixed up now.
You can try contacting the company or try to Google the pinout sheet though I doubt Google would help you.
iam using a hdmi to vga convertor device for connecting my laptop to the projector
i accedentilly pulled the wire of hdmi from the vga converter pins, the vga converter device also contains 13 pins same as there are in hdmi wires
I see.
