Connecting Lighting Node Pro and Corsair LL 120 fans
camo1206
22
I have a Corsair carbide omega RGB that came with two fans and Lighting Node Pro. I bought an additional 2 Corsair LL 120 RGB fans to install. With the case included fans I see the 4 pin connectors that plug into the motherboard and the RGB power cable that plugs into the Lighting Node Pro; simple enough; however, The Fans that I bought I only see the 4 pin connector that I assume plugs into the motherboard; and no separate cable that run to the lighting node Pro. Lost. Do those cables just run to the pro? or MOBO?
Motherboard is MSI X470 Gaming Pro
Lutfij
The LL's should have two leads, one for PWM signalling and the other end should go into the controller/hub
Here is the manual to pair the Lighting Node Pro and the fan hub.
Mind sharing if you have other fans/coolers you're working with?
