Question Connecting More ADD-RGB fans to my PC
Apr 26, 2019
I am going to buy a new PC. My case has space for 6 120mm fans. So I chose to buy 2 DEEPCOOL CF120 3 In 1 ARGB. I would also have a wraith prism stock cooler and one led strip. I buying GIGABYTE X470 AORUS ULTRA GAMING. So can I connect all the ARGB fans to my mobo, including the stock cooler (which is also argb ) and also the LEDs through a controller? If I can't connect all to the mobo, is there any way I can sync all the fans?
GIGABYTE X470 AORUS ULTRA GAMING:
https://www.gigabyte.com/in/Motherboard/X470-AORUS-ULTRA-GAMING-rev-10#kf
http://www.deepcool.com/product/dcoolingaccessory/2018-05/12_8348.shtml
I'm sorry I couldn't the specs for stock cooler.
  1. 2 x digital LED strip headers
  2. 2 x digital LED strip power select jumpers
  3. 1 x CPU cooler LED strip/RGB LED strip header
  4. 1 x RGB (RGBW) LED strip header
Per mobo specs
2x ARGB 4pin headers.
2x 5v-12v selectors for those headers.
1x A(?) RGB cpu header.
1x 5pin RGB+White header.
Shouldnt be an issue using both the deepcool kits on the 4 pin headers, and the Prism to the cpu header, but you may have problems with the strip if it's not RGBW 5pin. Technically you can gang all 6 fans under 1 connection, but that's a mess of splitters.
You sync everything through the software.
