Hi all,
I'm a newcomer to building pcs and I've been having a bunch of problems but right now I just got my pc to boot to the Bios without the graphics card in or the optical drive attached, so I i just had cpu, cooler, 1 stick of ram and a ssd hooked up. Now I want to install the graphics card and the optical drive.
But I'm a little nervous since I've gotten the build to bios before on just the barebones and even managed to install windows eight but each time I've plugged in the graphics card I haven't been able to post and have had to do a complete rebuild.
I think there's a chance I might be powering the graphics card wrong and would love some input.
I'm using an EVGA supernova 850 g2 and an MSI GTX 980 gaming 4G. The graphics card came with a 6 pin to 8 pin adapter and the power supply came with a VGA cable that was what I think is called a 6+2 pin cable that also had an additional 6 pin piece splitting off the 6+2.
I had been putting the 6 pin to 8 pin adapter on the 6 pin piece and plugging the 6+2 and the 6-8 adapter into the two 8 pin ports in the graphics card.
Should I be using two VGA cables instead?
The 6+2 pin cable appears to have a pentagon shaped piece where it should have a square piece if you know what I mean, I can post pics and additional information on my build if helpful.
Thanks all
Thanks all
