Hi i have a OMEN by HP Laptop PC - 15-ax003ng (ENERGY STAR) (product name: W6Z67EA#ABD) with the specs below.
I want to buy a monitor since my monitor is just 15,6" and i cant see much details in games. I researched a bit about connecting monitors to laptops and find a monitor that can work with my laptop. I found the Viewsonic VX2758-C-MHD that can perform 144hz (specs here) with support of HDMI v2.0 -My laptop supports HDMI v2.0 says here in the 7. page first column here (USER GUIDE FROM HP WEBSITE; better you can check it too) and my GPU (NVIDIA GeForce GTX 965M) should be supporting 144hz , i saw once in NVIDIA Webstite but cannot find the link agani-
I do experienced FPS drops in some games before but after i bought a laptop cooler and transfer the game i play to SSD from HDD- it seems to be working better.
So i just wanna know in the first place if i will be able to see 144fps-hz if i connect it with HDMI 2:0 cable. After all that; Will gaming with a monitor like that drop my FPS too low and so i wont be able to see the 144hz in monitor and force the PC to work so hard, will it be a bust, What do you guys think? The first question is more important tho, will that work at all?
PC SPECS
Product number
W6Z67EA
Product name
Microprocessor
Intel® Core™ i7-6700HQ (2.6 GHz, up to 3.5 GHz, 6 MB cache, 4 cores)
Chipset
Intel HM170
Memory, standard
16 GB DDR4-2133 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 965M (4 GB GDDR5 dedicated)
Hard drive
2 TB 5400 rpm SATA(i have a 128GB SSD too no idea why it doesnt say here )
Display
39.6 cm (15.6") diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard with numeric keypad
Pointing device
HP Imagepad with multi-touch gesture support
Wireless connectivity
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
Network interface
Integrated 10/100/1000 Gigabit Ethernet LAN
Expansion slots
1 multi-format SD media card reader
External ports
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.0; 1 RJ-45
Minimum dimensions (W x D x H)
38.2 x 25.3 x 2.45 cm
Weight
2.2 kg
Power supply type
120 W AC power adapter
Battery type
3-cell, 61.5 Wh Li-ion
Webcam
HP Wide Vision HD Camera with dual array digital microphone
Audio features
Bang & Olufsen; HP Audio Boost; Dual speakers
Software
Operating system
Windows 10 Home 64
HP apps
HP CoolSense; HP Lounge
Software included
McAfee LiveSafe™
Pre-installed software
CyberLink PowerDirector; Netflix; Unigine Valley Benchmark
Software - Productivity & finance
1 month trial for new Microsoft® Office 365 customers
PC SPECS
Product number
W6Z67EA
Product name
Microprocessor
Chipset
Intel HM170
Memory, standard
Video graphics
Hard drive
Display
Keyboard
Pointing device
Network interface
Expansion slots
External ports
Weight
2.2 kg
Power supply type
Battery type
Webcam
Audio features
Software
Operating system
Windows 10 Home 64
HP apps
Software included
McAfee LiveSafe™
