I have an STR DH810 that I can currently hook up 2 JBL speakers and a Polk Audio woofer to. I want to connect my Vizio SB3820 sound bar to it. At the moment I'm not using my receiver for my TV and just have the Vizio SB hooked up directly with an optical cable. I want to connect that same optical cable from my SB to the receiver but am not having any luck getting sound out of it. I'm very much a noob at hooking up receivers and this one has so many options and inputs I'm wondering if someone is familiar with this receiver model and might be able to shed some light for me so I can use all of the above mentioned speakers with it.
Thanks,
T4
Thanks,
T4
