The new case has a 3 pin connector for the reset switch but the power switch, power LED, and hard drive light connectors are all two pin.
The motherboard has a series of nine pins on the header and the diagram in the link below shows the reset pins as two next to each other but the connector has the two outside pins that are wired (so the middle one is dead).
https://goo.gl/images/GPFyt6
Here's the connector
https://www.dropbox.com/s/ua78jlrizkoglba/20171214_155107.png?dl=0
I'm wondering is it wired correctly or is the diagram correct? And will it cause a problem if I try to hook it up and try it?
Thanks,
Tim
Thanks,
Tim
