CONNECTING POWER SUPPLY TO P5N-E SLI MOTHERBOARD
PorterWilliam
Hello,
Power is connected and system green light is lit. But am not hearing any memory check during boot and have no video to be able to get to bios? Any ideas?
ulysses35
Does your mobo or case have a speaker ? a sure fire way of knowing if you have a problem is from the beep code - providing you have an audio output device connected.
Failing that go back and check every connection - the power ones to the mobo being the most obvious and also to the video card if it needs one.
