Question Connecting RGB fans from hub to motherboard
nidarekun
Hello,
I have 6 pcs RGB fans Rakk Maris X2 and Maris Pro fans and I have a simple question regarding how to connect and what to use.
My Fan Hub has:
10 Fan Inputs
2 Led Strip Inputs
1 Reset
1 Power
1 IR (I don't know what this is)
If I will use 3 pin RGB connector where should I connect it to the Hub in order to connect it to the mobo?
Thank you
Hi @Lutfij , thank you for your reply.
Here is the image from the link that you gave me regarding the Hub (PHOTO CTTO):
It has 6 pins:
And here is a picture of the fan connectors:
and
