There's an RGB strip perhaps 12" long inside the case, however the cable isn't connected to the mobo and it looks like a molex connection. I thought most RGB strips connect to the JRGB ports on the mobo.
It's definitely not connected to the Mobo as I installed a B450 recently and nothing is connected to the JRGB ports. any idea ?
My front two intakes are also molex.
Here you can see the connections.... if i could somehow connect that 12v strip to my mobo i'd be able to control the colours ( i think ) ....
