Connecting Speakers and a wireless transmitter to the same receiver output
rcarrollct
I'm looking to connect wireless speakers to my zone 2 output on my Denon receiver. I already have 2 speakers connected to my zone 2 via hardwire. I would like to add a wireless transmitter and then add outdoor wireless speakers to the same zone.
Is this possible? I know I can't use an RCA connector but if I find a transmitter that has L/R connection could I connect multiple units to the same output or will I risk damaging the system?
Thanks for this, so if I use this I should be able to connect any wireless transmitter / speaker combo?
Hi. I am also trying to do this but am failing to understand how to connect. Should I connect the speakers + the IN wires of the adapter to the AV Receiver output, and then the transmitter to the RCA on the other side of the adapter ?
The bit I'm not sure is if I should connect the regular speakers AND the adapter to the exact same outputs of the receiver.
Any help is welcome.
Thanks,
G.
Thanks for the quick reply !
In fact I'm thinking of wiring it to Zone 1 (Zone 2 does have indeed preamp outs) not Zone 2, but the your answer still applies.
I was mostly concerned about overloading the outs in the receiver, which you cleared out with your reply.
Thanks,
Gonçalo
