So i have a JBl creature II whose speakers don't work anymore: https://www.google.com.ar/search?q=jbl+creature+II&rlz=1C1ASUM_enAR675AR675&tbm=isch&imgil=riV6cM0SodW5kM%253A%253B1hb0jMj06roB1M%253Bhttp%25253A%25252F%25252Fwww.productreview.com.au%25252Fp%25252Fjbl-creature-ii.html&source=iu&pf=m&fir=riV6cM0SodW5kM%253A%252C1hb0jMj06roB1M%252C_&usg=__AzD9twXoFBjDYVOl7csAmlRdVO4%3D&biw=1745&bih=890&ved=0ahUKEwjk9seCzfrKAhWEIZAKHQY9BbYQyjcILw&ei=JzTCVqTHJ4TDwASG-pSwCw#imgrc=riV6cM0SodW5kM%3A
I'm using a brookstone idesign stack as my PC speakers but they don't have ANY bass sound.
So is there a way to use only the JBL's sub and the other speakers?
Brookstone is all wired up, you can't unplug the speakers from the "central controller"
On the other hand JBLs speakers can be detached. In this set the Subwoofer works also as the main control (both speakers are connected to it and this is the one connected to the pc)
So is there a way to work this out?
Please ask me any other information you need to answer my question.
Thanks a lot!!
Thanks a lot!!
