Connecting the front panel connectors to Motherboard
you see the black aluminum heatsink on the bottom edge of the board. there is a block of pins bright white in the same corner just below the screw hole. that is the F_Panel connector. the reset, power, hdd LED, Prw LED, and speaker should all be in that white block of pins. if you look under the pin block you can see labels as to what pins correspond to what.
Yeah, I see that the labels show: +PLED-, +PW-, +HD-, -RES+, +SPEAK-, -CI+ and +PWR_LED-
Can you tell me where I should I connect the: RESET SW, POWER SW, HDD LED, POWER LED + and POWER LED -
I would really appreciate it, thanks!
