Question Connecting these fans to neo air case
Oct 4, 2020
So my new metallic gear neo air case came with 2 fans pre installed with below connections View: http://imgur.com/a/fOnw1gW
these current daisy chain, run off the mobo header and the RGB is running through just one RGB connection of a cool.master RGB controller
So I ordered 3 extra fans check the description then they turn up with the follow connections
View: http://imgur.com/a/YVtmL1h
But none will fit into the daisy chain to run the RGB is there any adapter I can get to run all these with the different connections
You might want to mention the model for the controller used, CoolerMaster have a number of them. You also need to mention the make and model of your motherboard. We can't guess things from this end.
Sorry my bad thought I put everything The below device was used https://www.amazon.co.uk/dp/B071JY88NX/ref=cm_sw_r_cp_apa_i_4KCEFbGF8X0RH but this only seemed to be needed to connect the RGB control that went to the front panel no the actual fans my mobi is Asus b150m-a
Case I mention
https://www.amazon.co.uk/dp/B07WMRGFCQ/ref=cm_sw_r_cp_apa_i_xPCEFbX5XZZ8Y
