Connecting two cat5e sockets in parrallel
clarke24
im trying to connect two cat5e sockets in parrallel but when i do i lose my connection. I thought at first it was because i was putting two lots of wires in the back but i have tried it by placing the second set of wires in with the end stripped and i losethe connection whenever i connect either the orange/white or the green cables.
Can anyone help?
i have a socket on the wall and i want to put a socket under my desk only one will be used at anytime. I dont want to lose the connection on the wall incae i ever need to plug in at that point so i thought i would be able to simply spur off the original socket.
You've lost me.
Only thing I can guess is *maybe* you're trying to connect two ethernet devices over a single ethernet cable. It's best just to use switches, but they do make adapters, one you place on each end, that allow TWO ethernet devices to share a single ethernet cable. Not something I recommend, not something I can imagine using myself, but they do exist.
http://www.amazon.com/gp/product/B00288Z0Q6/ (note, MUST be used in pairs)
Otherwise, if I'm way off base, nevermind.
