• Find an incredible deal for Black Friday or Cyber Monday? Share those epic bargains with the community by posting them in this forum thread!
Question Connecting two devices to believe they are directly connected
Nov 12, 2019
Is there a simple way of connecting two devices in different physical locations to make them think they are directly connected via Ethernet? Apologies if this is a blatant newbie question.
The only answer you will likely understand is a simple no it can't be done.
If you really want to know you can look up what the following means. There is a method that is not commonly used called L2tpv3 that allows a layer 2 network to span a layer 3 network. You will not find this ability on common consumer routers. It takes a lot of cpu power to run.
Reactions: joejesney
Nov 12, 2019
Cheers! Reckon I’ve got my head round that! Two Cisco 2811’s ordered! Thanks
