Connecting USB 3.0 to USB 3.1 Ports???
Iver Hicarte
420
18
18,795
So all of my flash drives are version 3.0 and my case has 3.1 usb ports. So will the speed of my flash drives improve since I connected them to a usb 3.1 port??? Or will the speed be similar to a usb 3.0 speed?? Hope you understand my question guys. Can't rephrase them in a better way.
To my knowledge, the version of a drive affects the speed of the drive...again this is to my knowledge.
THANKS IN ADVANCE!!!
Lowest speed/version should govern but there will still be some minor improvements.
E.g.: USB3.0 flash drive on USB2.0 port = Significantly faster USB2.0 (not USB3.0) speeds
http://www.anandtech.com/show/4523/usb-30-flash-drive-roundup/6
E.g.: USB2.0 flash drive on USB3.0 port = Slightly faster USB2.0 speeds
http://www.anandtech.com/show/4523/usb-30-flash-drive-roundup/7
In your case, the USB3.1 flash drive should perform better on a USB3.0 port compared to using a USB3.0 flash drive on the same port, based on the tests made by anandtech in the links above.
Usb 3.1 Gen 1 is still USB 3.0, just renamed to this.
USB 3.1 gen 2 is the newer protocol with theoretical 10Gbps
Most cases are still usb 3.1 Gen 1 (5Gbps).
The speed of the flash drives will depend on the flash used and whether the usb port can support that bandwidth.
