A astrofighter122 Honorable Mar 31, 2015 282 0 10,780 May 5, 2016 #1 In your average PC case, there are normally two USB ports. Does each port have its own front panel connectors, and how do you install them?
Solution ThatVietGuy May 5, 2016 Usually two front panel ports are supplied by ONE cable that will plug into a header on your motherboard.
ThatVietGuy Titan Nov 6, 2007 11,726 318 70,240 May 5, 2016 Solution #2 Usually two front panel ports are supplied by ONE cable that will plug into a header on your motherboard. Upvote 0 Downvote Solution
A astrofighter122 Honorable Mar 31, 2015 282 0 10,780 May 5, 2016 #3 ThatVietGuy : Usually two front panel ports are supplied by ONE cable that will plug into a header on your motherboard. Is this for USB 2.0 or 3.0? Upvote 0 Downvote
