Connecting Wii to a DVI PC Monitor
gokussj9
35
The practical answer is you don't. If you insist you need an active converter which will run $50+ and I can't find any that do dvi. Theoretically you could get an RCA to HDMI box and use an HDMI to DVI cable.
www.amazon.com/Mini-Composite-CVBS-Converter-Input/dp/B00I482KZI
Not to be silly but the best thing to do might be to communicate with a specialist like Monoprice or another group that knows connectors and cables well.
keep learning and best of luck. "The harder I work the luckier I get"").
Walt Prill
