Hi all,
PROBLEM:
Server and desktop PCs in server room have no internet connection. The main wireless router is located in another room, and signal reception is good in server room.
QUESTION:
I have a very old (5-6 years old model) Belkin wireless router (with LAN ports) which unfortunately can't be used for wireless bridging.
In the meanwhile I found a USB wireless adapter (Belkin USB Wireless F6D4050 v2). I thought of using it for signal reception, and passing the signal to router (using USB-to-RJ45 adapter), and then distributed to PCs.
But before buying USB-to-RJ45 adapter, I thought of getting advice from forum. Would this scheme work?
Is it possible get working connection established between a USB wireless adapter and LAN router via USB-to-RJ45 adapter?
Belkin USB wireless adapter F6D4050 v2:
USB-to-RJ45 adapter
Belkin wireless + LAN router N150 (wireless bridging unavailable with this 2009 model)
PROBLEM:
QUESTION:
USB-to-RJ45 adapter
