C Clairef Prominent May 16, 2017 3 0 510 May 16, 2017 #1 I have xbox360 e, monitor with no speakers and external trust tytan gaming speakers. As there is no component lead am struggling to connect all 3 successfully. Can it be done?
Solution Kenton82 May 16, 2017 Yes, you could use one of these audio extractors! https://www.amazon.co.uk/ViewHD-Audio-Extractor-Converter-Model/dp/B00KBHX072 Output from the red & white RCA terminals to speakers. Hope this helps! K.
Kenton82 Reputable Jan 4, 2017 1,301 1 5,965 May 16, 2017 Solution #2 Yes, you could use one of these audio extractors! https://www.amazon.co.uk/ViewHD-Audio-Extractor-Converter-Model/dp/B00KBHX072 Output from the red & white RCA terminals to speakers. Hope this helps! K. Upvote 0 Downvote Solution
C Clairef Prominent May 16, 2017 3 0 510 May 16, 2017 #3 Kenton82 : Yes, you could use one of these audio extractors! https://www.amazon.co.uk/ViewHD-Audio-Extractor-Converter-Model/dp/B00KBHX072 Output from the red & white RCA terminals to speakers. Hope this helps! K. Upvote 0 Downvote
C Clairef Prominent May 16, 2017 3 0 510 May 16, 2017 #4 Thank you will give it a go! Upvote 0 Downvote
Kenton82 Reputable Jan 4, 2017 1,301 1 5,965 May 16, 2017 #5 Clairef : Thank you will give it a go! No problem, let me know how you get on! K. Upvote 0 Downvote
