Connection between router and blu-ray
tdwedge
Hello,do i need a x-over cable between router and blu-ray to watch netflix. wireless singal to weak to work.
Crossover cables are normally used for connecting two routers or two PCs directly, and are irrelevant to wireless signal strength. Netfilx HD rarely peaks 5MBPS, so unless you have a terrible WiFi signal, wireless usually isn't a problem... That being said, if your wireless signal is weak to your BD player, and you have the option to use a standard ethernet cable, go for it. You will get a more stable connection via wired connection.
