Hello, I have two power supply (1000 watt each) that I want to connect six GTX 1070 GPUs to them
3 GPUs to each power supply for a mining rig.
each GPU has dual 8-pin connector/opening
https://imgur.com/mMiL09Q
so obviously I need 12 pci-e 8-pin connectors total..
the problem is that each PSU has only 5 pci-e 8-pin connectors/opening
https://imgur.com/aV79KZy
so I was wondering if I can use this cable ( is it esp to dual pci-e 6+2 pin? )
https://imgur.com/78MutRD
to connect one more GPU to each PSU.
this cable head fits in the CPU slot/opening easily and the dual
6+2 heads fit in the GPU connectors as well. the head of this cable (the 8-pin one) DOES NOT FIT IN THE SLOT LABELED GPU, IT FITS IN THE SLOT LABELED CPU
so what do you think? is it safe to use that cable?
thank you.
thank you.
