Hi there, I hope you can help me. In my house we have a LAN powered by a TP-Link TD-W8950ND wireless router and several devices connected: laptops (PC and Mac), smartphones and consoles.
Some of our devices, though, have problems connecting to the network. My Macbook Pro connects perfectly under MacOS X, but under Win 7 goes into a loop during the authentication check. My Android phone (Nexus 4) returns an authentication problem and another Motorola Android phone cannot even see the network.
Now here's what I already tried:
- reset/reboot these devices and/or the router
- manually adding the network does not solve the issue
- SSID is broadcasted
- no Mac Address Filtering whatsoever
- drivers are up-to-date
- DHCP provides enough addresses for everybody
- static IPs do not solve the situation
- switching to Airplane mode on the phones also does not work
- all test are being done in the same room as the router, no signal strength issues
- all such devices work perfectly on other networks, nor they showed any similar problem before
I'm the only one in the house with above average knowledge in this matter, but I've ran out of ideas. I hope somebody here can help me out.
Thanks
Thanks
