Question Connection to front panel USB Type C
Jul 28, 2020
13
Probably a stupid question, but I wanted to be sure before I started buying components. Won't be my first build, but it's been a while.
I like the Fractal Design cases (using one now) and I'm looking at the Define R6 USB-C with a Type C connector in front. Probably going with a B550 motherboard. I've identified several that have a USB 3.2 Gen 2 Type C header, e.g. ASUS ROG STRIX B550E Gaming. My question is whether I can connect this to the front panel. Fractal Design indicates that the connector is USB 3.1 Gen 2 Type C. Is that a problem? Maybe I should just forget the front panel and use the rear panel 2 Type C connector when I need to.
Thank you in advance.
