Hello Everybody,
I am having some problem of connectivity between ADSL wireless modem router and another wireless router. The HUAWEI Quidway Wa1003A ADSL Modem-Router (provided by BSNL, my ISP), having 1 USB port/1 WAN port/1 LAN port, is connected over Ethernet cable with my desktop in my 1st floor. I have a laptop also, which i generally use in the 2nd floor. But the wireless signal is very poor in the 2nd floor due to the walls. I have one ASUS RT-G32 Wireless-G Router having 1 WAN Port and 4 LAN port. So, placed the ASUS Wireless Router in the 2nd floor and tried to connect those two routers through Ethernet cable to get good wireless signal for my laptop. I connected those two routers using Crossover Ethernet Cable (checked that cable with cable checker). Set the IP of the modem-router as 192.168.1.2. Subnet Mask : 255.255.255.0 and did not put any value in the Gateway. I disabled Wireless option and kept DHCP Server ON. I also put the username and password over there to get always on internet service.
For ASUS RT-G32 wireless router, i put an IP : 192.168.1.3, Subnet Mask : 255.255.255.0 and Gateway : 192.168.1.2. Wireless option is enabled and DHCP is disabled. After that i found neither of the LAN indicator of HUAWEI modem-router nor, the LAN port indicator of the ASUS RT-G32 router were glowing and there is no internet connectivity found in that network.
Please advice me how to connect those router and get wired & wireless connectivity from ASUS router as well as from HUAWAI ADSL Modem-router.
Thanks in advance,
Thanks in advance,
