Approximate Purchase Date: e.g.: This week (ASAP)
Budget Range: 2000-2500
System Usage from Most to Least Important: Gaming (Overwatch, Mass Effect Andromeda), surfing the internet
Preferred Website(s) for Parts: I've "built" a custom computer on ibuypower.com because I am a former console peasant with no experience when it comes to PCs. Here's what I came up with so far:
iBUYPOWER Labs - Noise Reduction 1 x Basic - iBUYPOWER Harmony SRS Sound Reduction System (Foam + Silent Fans) - Reduce System Noise (is this even worth it if I will be wearing headphones most of the time??)
Processor 1 x Intel® Core™ i7-8700K Processor (6x 3.70GHz/12MB L3 Cache) - Intel® Core™ i7-8700K
iBUYPOWER PowerDrive 1 x PowerDrive Level 1 - Up to 10% Overclocking
Processor Cooling 1 x Asetek 570LXL 240mm Liquid CPU Cooling System
Memory 1 x 16 GB [8 GB X2] DDR4-3000 G.SKILL Trident Z RGB Memory
Video Card 1 x NVIDIA GeForce GTX 1080 Ti - 11GB (VR Ready) - Single Card
Motherboard 1 x ASUS PRIME Z370-P -- 2x PCIe x16, 4x USB 3.1, 2x USB 2.0 [Intel Optane Ready] (is this good enough? Or should I upgrade to the Assus ROG Strix Z370-E?)
Power Supply 1 x 850 Watt - Thermaltake Toughpower Grand RGB 850W Gold Full Modular
Primary Hard Drive 1 x 240GB ADATA SU650 SSD (is this enough? or should I go for the Samsung 960 Evo 1TB?)
Data Hard Drive 1 x 2 TB Hard Drive -- 64MB Cache, 7200RPM, 6.0Gb/s - Single Drive
Overclocking: Yes
SLI or Crossfire: No / Maybe (I don't really understand what that means)
Your Monitor Resolution: 2560x1440
Additional Comments: I have no idea what I'm doing. 🙁 I just want a really good gaming rig that will be equipped to handle games for years and could really use some help/critiques. Thank you so much!
Overclocking: Yes
