Constant AUDIO stutters
Dem_Mak
11
Okay, so I'm no expert in this kind of stuff, but it has really been bothering me lately that i keep getting constant audio stutters. There's a 1/10 chance that my computer's audio will not stutter when i turn it on. It has usually worked when i turned on my computer and at first it didn't work but then i shut it down and turned it back on in 30 minutes and it worked. I don't know why all of this has been happening .
I've tried hard resetting my computer and reinstalling the drivers and it didn't work (only sometimes). I've been using windows 10 for a long time and i've never had this problem before, so I doubt downgrading the OS would help, but lately i've been getting these stutters so frequently that it's getting really annoying. Because of audio stutters i get video stutters too.
I don't know if this helps but here are my PC specs:
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core 2 Quad Q6600 @ 2.40GHz 48 °C
Kentsfield 65nm Technology
RAM
4.00GB Dual-Channel DDR2 @ 399MHz (5-5-5-15)
Motherboard
ASUSTeK Computer INC. P5Q-PRO (LGA 775)
Graphics
DELL 2001FP (1600x1200@60Hz)
2048MB ATI AMD Radeon HD 7800 Series (Gigabyte)
Storage
298GB Western Digital WDC WD3200AAKS-00VYA0 (SATA)
465GB Western Digital WDC WD5000AAKS-65TMA0 (SATA)
Optical Drives
Optiarc DVD RW AD-7173S
Audio
AMD High Definition Audio Device
Can anyone help? Is my sound card faulty or something?
Thank you for taking your time to read this.
This is from local files (on your computer) or just internet?
Have you tried running MalwareBytes to make sure malware isn't causing some kind of bogging down?
Do you have much other processes running in the background eating up your RAM? .. 4 gig is pretty low to begin with
it's not just the internet, it's also the local files.. I'll try, thank you
