Yes, it's normal when power saving functions are enabled, it reacts to CPU load and lower frequency when not needed under no/light load. If you want, you can change Minimum frequency in Control panel > Power options > Advanced > CPU.
i set it to high performance and now its always 4000 mhz. i set it to power saver and its always 800 mhz. i want the balanced one but why does it fluctuate to both ends constantly?
