Constant pop-up in games caused by power supply?
RageKage14
73
My specs:
i5 4430
Radeon R9 270
GA-H81M-H
4GB Kingston HyperxBlu
600W Thermaltake dual rail PSU
I have a problem of textures popping in extremely close whenever I walk in games.
https://www.youtube.com/watch?v=XlppdH8rceQ
I was told on Reddit techsupport that my original PSU (Dell h750e-01) was poor for my setup because it was quad rail and my video card wasn't drawing enough power. I went out yesterday and bought the 600w dual rail and the problem is still there. Now I am being told that I need specifically a SINGLE rail psu. Is this really the issue that would be causing this texture pop in?
try pulling the sound jack and reinserting it.
ever think about setting your brightness and contrast features up right?............. this would be within the monitors control panel.
the stuff about the PS ............. BS................... what power supply did you have and what one did you get?
What you are seeing is LOD set way way way too low. Go into your settings and turn the LOD up, this has nothing to do with your power supply at all. Even if you were not getting sufficient power to the card it would not cause an issue like this, you would get freezes or very low fps spikes.
Edit: It might be called Draw Distance in Far Cry 3. Been a minute since I played it and at work and cant actually check it from here.
I would seriously doubt your power supply could cause effects like that. Your GPU or GPU driver could. Just out of curiosity, when you are ingame, how much of your RAM is being used? 85-95%? I wonder if that could be an effect of pagefile access to your hard drive because your RAM is saturated?
Definitely not the PSU. I would check your driver and see if you have a global game profile enabled. If have allowed the driver to override the application settings it can easily cause issues like this as well.
How much disk space do you have allocated to your swap file? Also what kind of drive and what RPM does it run at? This could certainly be caused by a slower disk being used as virtual RAM (as skit75 mentioned earlier).
This is now the third person on Resdit to tell me the power supply is at fault. I don't know what to do.
http://www.reddit.com/r/techsupport/comments/26540o/textureshadow_popin_in_every_game_i_try_to_play/
That is one of the most unstable power supplies on the market , could be an issue.
Tier 5 - Other than the units listed above for any of these brands, NOT RECOMMENDED. Replace ASAP if you have one.
A-TOP Technology
Apevia
APEX (SUPERCASE/ALLIED)
Aspire(Turbo Case)
ATADC
Athena Power
ATRIX
Broadway Com Corp
Coolmax
Deer
Diablotek
Dynapower USA
Dynex
EagleTech
FOXCONN
FSP Everest
HEC Orion
Hiper Type-R
Huntkey
I-Star Computer Co. Ltd
In Win
JPAC COMPUTER
Just PC
Kingwin Inc.
Linkworld Electronics
Logisys Computer
MGE
MSI
NMEDIAPC
Norwood Micro/ CompUSA
NorthQ
NZXT
Okia
Powmax
Q-Tec
Raidmax
Rocketfish
Rosewill
SFC
Shuttle
Skyhawk
Spire Coolers
Star Micro
STARTECH
Thermaltake Purepower NP
Thermaltake Purepower RU
Thermaltake TR2 (and TR2-RX) :bounce:
TOPOWER TOP
Ultra X-Connect
Ultra X2 >greater than 700 watt
Ultra LSP
Wintech
XION
YoungYear
Zebronics
