Question Constant Stuttering in Games with massive fps drops and spike frametimes from 5ms upto 18ms
thejammie9
14
Hey All
Every single game I try to play seems to have hitches. The frametime spikes up causes a stutter and its easily noticeable and
getting to the point when trying to play games is just no longer fun. Happens on MW2 , BF2042 and PUBG And CSGO.
Does not matter what the settings are set to very low ultra its always there.
What I have done to try and fix the issue myself
Upgrade from a 3700x to a 5800x3d
Upgrade ram from Hyper x Predator 3200mhz kit to Corsair LPX 3600mhz kit
Fresh install of Windows 10 & 11 Pro With a full format of all drives
Fully rebuild the system to make sure everything is seated correctly
Run CSM/UFEI Both made no diffrence
Under volting the CPU & GPU
Set all fans in case & motherboard & gpu to 100%
Turn Gamemode off and on
Disable GPU Scheduling
Run games on low settings and normal settings
Check all temps CPU sits around 62c and gpu is 68c hotspot 78c
Change clock speeds of CPU to a locked base of 3500mhz and same to the gpu of 1800mhz
Limit framerates in games to 90fps 120fps and 144fps
Checked power supply and all voltages under load are normal and not changing. Powedraw from the wall is around 480w to 520w
XMP Off and on
SMT & SVM Off and on
TPM Settings Off and On
Bios Version Tried
7B93v1J-2023-05-11
7B93v1I-2023-03-06
7B93v1F-2022-03-31
7B93v1D-2021-07-07
I am honestly all out of ideas at this point on what my next steps are. Do I just go back to intel or is it something i am doing wrong
Specs
CPU: AMD Ryzen 7 5800X3D
MB: MSI X570 Pro Carbon Wifi
Ram: Corsair Vengeance LPX 32GB 16X2 3600mhz C18
Cooler: H115i V2
GPU: Gigabyte RTX 3070 AMPERE
M.2: Crucial P2 1TB - Game Drive
M.2: Crucial P1 1TB - OS & Program Drive
PSU: Corsair RM750
Mouse: Logitech G502
Keyboard: Logitech G513
Thanks to everyone who has took time to read this and give some support!
latest motherboard bios?
how full are the ssd?
cpu/gpu temp and usage during the game?
Sorry totally forgot to put in that list all the versions i tried of the bios for my board.
These are all the ones still on my Flash USB Version with Release date next to them
7B93v1J-2023-05-11
7B93v1I-2023-03-06
7B93v1F-2022-03-31
7B93v1D-2021-07-07
SSDS are pretty clean c: is 772gb free and the game drive is 331gb free
Temps during gaming are anywhere from 55c to 68c on the cpu and gpu 58c to 71c hotspot temps range from 65c to 81c
