I have had this problem from the very beginning.
My computer always has a white noise on all audio outputs from the motherboard (sound works otherwise). I have already tried the following and all of them made no difference:
- tried included Realtek drivers, tried older Realtek drivers and tried the latest Realtek drivers
- removed the GPUs one by one (R9 280X and HD 5450)
- updated BIOS to latest version
- touched a wire connected to ground against various metal parts of the case
This noise appears once the OS is started. There is no noise before that (during boot), but I guess that is simply because nothing is using audio at that moment.
I have Windows 7 Professional x64. I also tried Ubuntu 12 and the exact same noise emerged.
The noise does go away if I set the Windows speaker output level to zero or press the mute button. When not muted however, the noise is always equally as loud, no matter what level I set it to.
There is very little noise in other outputs though. I used a VCR to check the TOSLINK output and it was clean, so was the HDMI output of the GPU (R9 280X).
The noise also changes when I play Windows sounds (?).
My motherboard is a P9X79 LE, PSU is a Corsair AX760.
Speakers are completely fine. I tested them on another computer and there is no noise whatsoever. Just to be sure I even tried headphones that are working perfectly fine and they got noise too.
Same noise comes from the rear output and in the front panel output as well.
I am out of ideas. What is wrong here?
