Question Constantly loop of BSODS, need help with minidump file
Sick Jacken
48
Hello, a few weeks ago I got thrown into a loop of BSODS. Memory is fine, I've already tested I've also changed the voltage from 1.55v to 1.42, I thought it was voltage because the computer was running fine for more than 24hrs, currently.. hopefully Chrome will not give me random things such as STATUS BREAKPOINT or status access violation anyway.. I've ran chkdsk a lotta times, last time with x although the HDD is perfectly healthy as you see in the snapshot. I do have an all AMD system that's a few yrs old with the MOBO being from 2014ish and stuff, capacitors are all solid and healthy is an ASROCK fm2a58m hd with an amd a4 6320, also a RX 550 Pulse with 2 gigs all this packed by a 512W 80 plus bronze SeaSonic I do know AMD drivers are not horrible inexistent they do take heavy pride with their "Pro Software" but I couldn't install it sadly gave me error 1603. So I have everything for a desktop computer needed to work from all Visual CC all way to even XNA 4.0, directx run time updated k lite mega codecs ( installed with selected only 64bits comp). I can't upload minidump file as such it doesn't give me access.
View: https://imgur.com/a/bipR6Q2
This isn't linked to any component of mine in the computer, I've tested them over and over all temps are fine with a brand new thermal paste both to GPU/CPU/sata cable/cmos battery.
and on a bottom line, I managed to find some modded drivers that are far better than those on AMD's site, they're modded to make them more stable, especially on Polaris chipsets. It all started randomly back when I was still on Windows 7, randomly.. one night I turn it on next bam loops after loops after loops. It happend while I was playing CS:GO.. for now very least I know BSOD aren't tight to just one thing so mentioning either browsin or gaming doesn't make any sense I need to know why exactly. I've even read stuff such as fake BSOD screens.. I've checked the system over and over. Hitman Pro/malwarebytes I've heard causes BSOD so i've avoided anything under their guild and with the signature of Bitdefender that also causing bsod but man I needed a scan all this back when i was still on 7. Currently when I upgraded to 10, I didn't install any antivirus or software other than Steam for a few days just to see if Panda which I use it since back in the days might just might, ofc it wasn't as u might think twice.
if you have a minidump
  1. Open Windows File Explore
  2. Navigate to C:\Windows\Minidump
  3. Copy the mini-dump files out onto your Desktop
  4. Do not use Winzip, use the built in facility in Windows
  5. Select those files on your Desktop, right click them and choose 'Send to' - Compressed (zipped) folder
  6. Upload the zip file to the Cloud (OneDrive, DropBox . . . etc.)
  7. Then post a link here to the zip file, so we can take a look for you . . .
Reactions: Sick Jacken
I did over 10 OS installation am tired and one edge of throwin this PC outta window one edge.. Should I just do a BIOS reflash? i dunno. Today I've downloaded the auto detected utility by AMD, it updated my SMBUS, it wasn't previously installed on 10. Although is a shady motherboard I'll give you that, it's one shady motherboard... but it was cheaper and i didn't care.. i could've got that damn ASUS motherboard for 10 euros and it wasn't no issue, at least isn't as rock but man understand am an average joe i don't care about pc like i used once
https://www98.zippyshare.com/v/wB8Zz6Zh/file.html
@Colif
yooooooooo
i did it
i dunno it had logs i think the site man
  • Microsoft (R) Windows Debugger Version 10.0.18362.1 AMD64
    Copyright (c) Microsoft Corporation. All rights reserved.
    Loading Dump File [C:\inetpub\wwwroot\UploadedFiles\e7aac938-c71e-4133-a431-2f937113e354.dmp]
    Mini Kernel Dump File: Only registers and stack trace are available
    * Path validation summary **
    Response Time (ms) Location
    OK C:\inetpub\wwwroot\UploadedFiles
    Deferred cache*c:\symbols
    Deferred srv*https://msdl.microsoft.com/download/symbols
    Symbol search path is: C:\inetpub\wwwroot\UploadedFiles;cachec:\symbols;srv Executable search path is:
    Windows 10 Kernel Version 19041 MP (2 procs) Free x64
    Product: WinNt, suite: TerminalServer SingleUserTS Personal
    Built by: 19041.1.amd64fre.vb_release.191206-1406
    Machine Name:
    Kernel base = 0xfffff8045de00000 PsLoadedModuleList = 0xfffff8045ea2a270
    Debug session time: Wed May 4 06:18:55.074 2022 (UTC + 0:00)
    System Uptime: 0 days 0:18:37.777
    Loading Kernel Symbols
    Loading User Symbols
    Loading unloaded module list
    For analysis of this file, run !analyze -v
    .time
    vertarget
    Machine Name:
    !analyze -v
    • Bugcheck Analysis *
    SYSTEM_SERVICE_EXCEPTION (3b)
    An exception happened while executing a system service routine.
    Arguments:
    Arg1: 00000000c0000005, Exception code that caused the bugcheck
    Arg2: fffff8045e008d0c, Address of the instruction which caused the bugcheck
    Arg3: ffffa7843ab8d330, Address of the context record for the exception that caused the bugcheck
    Arg4: 0000000000000000, zero.
    Debugging Details:
    KEY_VALUES_STRING: 1
    PROCESSES_ANALYSIS: 1
    SERVICE_ANALYSIS: 1
    STACKHASH_ANALYSIS: 1
    TIMELINE_ANALYSIS: 1
    DUMP_CLASS: 1
    DUMP_QUALIFIER: 400
    BUILD_VERSION_STRING: 19041.1.amd64fre.vb_release.191206-1406
    SYSTEM_PRODUCT_NAME: To Be Filled By O.E.M.
    SYSTEM_SKU: To Be Filled By O.E.M.
    SYSTEM_VERSION: To Be Filled By O.E.M.
    BIOS_VENDOR: American Megatrends Inc.
    BIOS_VERSION: P2.20
    BIOS_DATE: 05/08/2015
    BASEBOARD_MANUFACTURER: ASRock
    BASEBOARD_PRODUCT: FM2A58M-HD+
    BASEBOARD_VERSION:
    DUMP_TYPE: 2
    BUGCHECK_P1: c0000005
    BUGCHECK_P2: fffff8045e008d0c
    BUGCHECK_P3: ffffa7843ab8d330
    BUGCHECK_P4: 0
    EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
    FAULTING_IP:
    nt!ExAcquireResourceExclusiveLite+1c
    fffff8045e008d0c 0fb7431a movzx eax,word ptr [rbx+1Ah] CONTEXT: ffffa7843ab8d330 -- (.cxr 0xffffa7843ab8d330) rax=ffffa982323020c0 rbx=efffa9822c557528 rcx=efffa9822c557501 rdx=0000000000000001 rsi=ffffa9823420ae68 rdi=efffa9822c557010 rip=fffff8045e008d0c rsp=ffffa7843ab8dd30 rbp=0000000000000705 r8=00000000ffffffff r9=7fffca82462f11b8 r10=fffff8045e008cf0 r11=ffff877924e00000 r12=0000000000000000 r13=ffffa982345edba8 r14=0000000000000001 r15=0000000000000706 iopl=0 nv up ei pl nz na pe nc cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00010202 nt!ExAcquireResourceExclusiveLite+0x1c: fffff8045e008d0c 0fb7431a movzx eax,word ptr [rbx+1Ah] ds:002b:efffa9822c557542=???? Resetting default scope BUGCHECK_STR: 0x3B_c0000005 CPU_COUNT: 2 CPU_MHZ: ed1 CPU_VENDOR: AuthenticAMD CPU_FAMILY: 15 CPU_MODEL: 13 CPU_STEPPING: 1 BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT PROCESS_NAME: PSANHost.exe CURRENT_IRQL: 0 ANALYSIS_SESSION_HOST: DebugLearn-Dev- ANALYSIS_SESSION_TIME: 05-04-2022 07:33:59.0387 ANALYSIS_VERSION: 10.0.18362.1 amd64fre LAST_CONTROL_TRANSFER: from fffff8045a1bd3d6 to fffff8045e008d0c STACK_TEXT: ffffa7843ab8dd30 fffff8045a1bd3d6 : ffffa982323020c0 ffffca82462f11b8 0000000000000706 ffffa9823420ae60 : nt!ExAcquireResourceExclusiveLite+0x1c ffffa7843ab8ddc0 fffff8045e4da889 : ffffca82462f11a8 ffffa9823420ae68 ffffca8200000000 ffffa982345edba8 : FLTMGR!DeleteStreamListCtrlCallback+0x56 ffffa7843ab8de00 fffff804602605ab : ffffca82462f1170 ffffa7843ab8df48 ffffa982345edba8 0000000000000703 : nt!FsRtlTeardownPerStreamContexts+0xc9 ffffa7843ab8de40 fffff80460260336 : ffffca82462f1170 ffffca82374de67d 0000000000000000 ffffa9822c5785d0 : Ntfs!NtfsDeleteScb+0x17b ffffa7843ab8dee0 fffff80460132795 : ffffca82462f1010 ffffca82462f1170 0000000000000000 ffffca82462f1170 : Ntfs!NtfsRemoveScb+0x66 ffffa7843ab8df40 fffff80460132469 : ffffca82462f0050 ffffa7843ab8e720 ffffa9822c577180 ffffca82462f1010 : Ntfs!NtfsPrepareFcbForRemoval+0x75 ffffa7843ab8df80 fffff8046026011a : ffffa982345edba8 ffffa9822c577180 ffffca82462f0010 ffffca82462f0528 : Ntfs!NtfsTeardownFromLcb+0x2c9 ffffa7843ab8e020 fffff804601139f0 : ffffa982345edba8 ffffa7843ab8e122 ffffca82462f0528 ffffca82462f0010 : Ntfs!NtfsTeardownStructures+0xea ffffa7843ab8e0a0 fffff804601f5a07 : ffffa7843ab8e200 ffffca8200000001 0000000000000000 fffff80400000000 : Ntfs!NtfsDecrementCloseCounts+0xb0 ffffa7843ab8e0e0 fffff804601f2524 : ffffa982345edba8 ffffca82462f0170 ffffca82462f0010 ffffa9822c577180 : Ntfs!NtfsCommonClose+0x467 ffffa7843ab8e1c0 fffff80460270054 : ffffa98200000001 0000000000000000 0000000000000000 ffffa9822c577a58 : Ntfs!NtfsFspCloseInternal+0x244 ffffa7843ab8e320 fffff8046013ca93 : ffffa9822c593c70 ffffa7843ab8e720 ffffa9822c593c70 ffffa9822c577100 : Ntfs!NtfsFlushVolume+0x10c ffffa7843ab8e430 fffff8046012aee5 : ffffa98234dca268 ffffa98231620a20 ffffa9822c593c70 ffffca8252f97401 : Ntfs!NtfsVolumeDasdIo+0x1eb ffffa7843ab8e4f0 fffff8046012a26c : ffffa98234dca268 ffffa98231620a20 ffffa98211000000 ffffa9822c557010 : Ntfs!NtfsCommonRead+0xa45 ffffa7843ab8e6f0 fffff8045e08f6f5 : ffffa9823155da20 ffffa98231620a20 ffffa98231620a20 ffffa9822c521da0 : Ntfs!NtfsFsdRead+0x1fc ffffa7843ab8e7c0 fffff8045a186c5f : ffffa7843ab8ea20 0000000000000000 0000000189b7a8c0 fffff8045e0a1138 : nt!IofCallDriver+0x55 ffffa7843ab8e800 fffff8045a184673 : ffffa7843ab8e890 0000000000000000 00000000279fdf80 fffff8045e3f5f01 : FLTMGR!FltpLegacyProcessingAfterPreCallbacksCompleted+0x28f ffffa7843ab8e870 fffff8045e08f6f5 : ffffa98231620a20 00000000051adc08 ffffa7843ab8eb80 0000000000000000 : FLTMGR!FltpDispatch+0xa3 ffffa7843ab8e8d0 fffff8045e4758f8 : 0000000000000000 ffffa982333b05c0 0000000000000001 ffffa9822c1f7c01 : nt!IofCallDriver+0x55 ffffa7843ab8e910 fffff8045e48c6b9 : ffffa98200000000 ffffa7843ab8eb80 0000000000000000 ffffa7843ab8eb80 : nt!IopSynchronousServiceTail+0x1a8 ffffa7843ab8e9b0 fffff8045e208bb8 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!NtReadFile+0x599 ffffa7843ab8ea90 00000000770b1cfc : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : nt!KiSystemServiceCopyEnd+0x28 0000000004b1f1a8 0000000000000000 : 0000000000000000 0000000000000000 0000000000000000 0000000000000000 : 0x770b1cfc THREAD_SHA1_HASH_MOD_FUNC: 892344cbf35e3515cb253fde5c8f03e16e78f613 THREAD_SHA1_HASH_MOD_FUNC_OFFSET: acdf8a7f6ee3471df3e628789529176ba9c8ab9b THREAD_SHA1_HASH_MOD: aad6d51fdf70b1844a75d94146a0d0e5aba29773 FOLLOWUP_IP: nt!ExAcquireResourceExclusiveLite+1c fffff8045e008d0c 0fb7431a movzx eax,word ptr [rbx+1Ah]
    FAULT_INSTR_CODE: 1a43b70f
    SYMBOL_STACK_INDEX: 0
    SYMBOL_NAME: nt!ExAcquireResourceExclusiveLite+1c
    FOLLOWUP_NAME: MachineOwner
    MODULE_NAME: nt
    IMAGE_NAME: ntkrnlmp.exe
    DEBUG_FLR_IMAGE_TIMESTAMP: 2f0a239f
    IMAGE_VERSION: 10.0.19041.1288
    STACK_COMMAND: .cxr 0xffffa7843ab8d330 ; kb
    BUCKET_ID_FUNC_OFFSET: 1c
    FAILURE_BUCKET_ID: 0x3B_c0000005_nt!ExAcquireResourceExclusiveLite
    PRIMARY_PROBLEM_CLASS: 0x3B_c0000005_nt!ExAcquireResourceExclusiveLite
    TARGET_TIME: 2022-05-04T06:18:55.000Z
    OSBUILD: 19041
    OSSERVICEPACK: 1288
    SERVICEPACK_NUMBER: 0
    OS_REVISION: 0
    SUITE_MASK: 784
    PRODUCT_TYPE: 1
    OSPLATFORM_TYPE: x64
    OSNAME: Windows 10
    OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
    OS_LOCALE:
    USER_LCID: 0
    OSBUILD_TIMESTAMP: 1995-01-04 04:27:11
    BUILDDATESTAMP_STR: 191206-1406
    BUILDLAB_STR: vb_release
    BUILDOSVER_STR: 10.0.19041.1.amd64fre.vb_release.191206-1406
    ANALYSIS_SESSION_ELAPSED_TIME: 2bc5
    ANALYSIS_SOURCE: KM
    FAILURE_ID_HASH_STRING: km:0x3b_c0000005_nt!exacquireresourceexclusivelite
    FAILURE_ID_HASH: {8a952d6e-9653-e332-6320-e4ba22371b9d}
    Followup: MachineOwner
Colif... damn
although in terms of aesthetics from what i've noticed they both look same of course given same chip but the settings didn't change and so i did a LOAD UEFI DEFAULTS and yet again my dram voltage auto was on 1.55v so i've lowered it to 1.42v. I don't run OC man I just want this to work 🙁 i ask much
another bsod >>> edit >> PSINKNC.sys ( panda antivirus integrations things ) before the BIOS downgrade, so all currently shown minidumps are P.2.20.. yeah i.. will have some self love and not ask'em to refund me but i will retrieve my year subscription from them.. now i couldn't actually unistall it fully because it said "Cancelling unistallation" so Revo didn't had the chance to actually get all of the leftovers.. now I am scared to install registry cleaners and stuff but nm
in a way it goods if i leave the system like this.. because after i've found the doomed vulnerability i can just do a clean install and enjoy my computer right that's why i've payed.. that's why i pay an ISP
1.60 may have been the version before 2.0.
Just cause I can find 1.60 and 1.40 advertising selves as right for board, I wouldn't download them.
Internet full of sites claiming to have downloads, sometimes they are lying
I wouldn't flash an older bios on, it might not help.
Dump files might reveal more.
It breaks it breaks I doubt driverscollection gives me malware, If by now my mobo would just brick and isn't Softpedia. Manufactuer fault fault for being a try hard gaslighter, currently installing some Windows updates which one is cumulative. Plus I cleaned all the leftovers using CCleaner
EDIT > I've googled the Cumulative update that couldn't install nor as a standalone isn't needed, isn't a quality is just a "security" ah remidns me back of 7 when you had more than 200 classified as security anyway.. I am clueless as to what antivirus to install, thinkin maybe to try Bitdefender but that damn auto pilot and all that vpn service.. i am scared to use defender because it's more likely to bsods with all these updates and speakin of updates, because I disabled defender with group policy now i can't install that "cumulative" update yeah, grudges. See, small things you need to feel them in hand before so other than that all updates installed perfectly 2nd time because it could've been first time but I didn't got app readiness enabled ahaha
https://www79.zippyshare.com/v/KNIvWWlQ/file.html
just fyi:
You should not take ownership of the minidump directory. You only get read access by default. You have to copy the files to a new location to use them
(zip). system should have full rights to the directory.
you should use a different file share service. people don't like sites that attempt to install a lot of malware on their computers.
I don't think I can beforehand, sucks to redo the process everytime but at least for now is first time I could actually do it, the "Find Now" button I never clicked it and wondered. So I hoped someone by now would give me some analysis and I don't think ZippyShare is a malware just use an AdBlock what convo is this.
I dunno but I've went to my mobo manual and it only says Windows 7/8.1 x64 by default.. I dunno.. I've had Windows 10 way way back when I was using a SSD from Gigabyte and was on 10. I dunno and it makes you think that there's no LAN driver for my specific RealTek chipset on 10 but there's for audio..
also on the internet it says Windows 10 drivers available because >> my mobo has some R7 some even my CPU HD8xxx some and I think that's why, at least the auto detect utility installed the amd smbus so it might be a glimmer of sparky fairytale wings here but even all dices doesn't get the cat outta hat. Please man, y'all help me I understand some might be busy but I think a damn analysis isn't that hard.. just tell me what I need to do. To install Windows 7 with over 200 updates to have same thing no, I wanna know first.. so my realtek lan chipset is 8111FR now i dunno how these realtek chipset work but there's no 8111fr but if you google alc662 ( audio ) you get windows 10/7\.
edit >> currently am typing from the "hive" the computer of bsods so see I think i can fix it, bc if i couldn't it wouldn't allow me to use it now
well if you can not get anyone to download your minidump you can always
give bluescreenview.exe or whocrashed.exe a shot
tbh i was once in pc too but we live in a world where there's no OTR anymore even the WinDbg is a discomombulated rookie ayahuasca trip, it makes no sense ( you could just as well analyze your minidump) part of me thinks debuglearn also does same thing but i need to know what am looking for, most is the bucket id win8 driver fault now what it means god knows, speaking of WC/BS i've tried them before and they aren't no analyzer, they say "kernel" well kernel is in everything, in browsers in drivers in even pictures even worse when you have two language pack installed on your OS, so this being said i think the process name is what am looking for if not at very least i am gonna leave the thread open i don't bother to delete it or some, never knows what i might get from here.. i am going to sysnative, hopefuly they'll help me. I've already got i just copypaste
I was able tonight like a few others night as well.. to try and test the system in'games as opposed to benchmarks because benchmarks aren't real you need games for it to see and tomb raider worked well until by now i type, i just pickedup the first game ( 2013 ) i love Lara. So people can as well see "well why not help this man, because we see his hardware is all healthy let's try to see if we can fix this man os, maybe i will encounter in the near future" never knows but i dont say
Just a quick follow'up update so I call him.. now my HDD is in GPT! Yes.. I have a thing called CSM so i've disabled that and now I use the dystopian UEFI ah and like without OS reinstallation now I am not sure how safe this might be but of course given how Windows is.. nothing is safe
the bugcheck was an access violation in some nt filesystem clean up code most likely from a file filter driver from Panda Internet Security
generally this would be caused by: outdated panda driver,
outdated network drivers can mess up these filter drivers.
your system bios is from 2015, you might want to update your motherboard bios and various drivers. I would remove the panda driver or update it.
without looking at the actual drivers info it is hard to tell if they have been updated.
since the error code was access violation, there are just too many potential causes to say for sure what cause this without looking at the dump in the debugger.
ahaha, long time no see. I came to say what I've did.. I didn't do anything that's what I did. Now I use EFI/GPT aside from that I managed to find out that the latest realtek audio for alc662 // 2.82 \\ is actually broken, it doesn't show the HD mananger it says enabled in msconfig/available in searching index in Windows folder, doesn't open. After this, I've been a collateral victim they think but am sick jacken after all, the sysnative is purely a shady website, made out of 300 members and only 10 people who are "voluntars" hear out, voluntars, they were an energy worm. I made the PC I think overall a bit steady, not stable yet.. I need to know and find someone who's willing to point out that those windows update cause bsod and if so which.. added/removed, do y'all think that 21h1 is more stable as opposed to 21h2? that's what I wanna know.. I can't get BSOD because of driver issues because I don't got any external peripherals other than a dedicated video card and my drivers mainly consist in just even not 10 by numbers. Now my bios is again to latest ( P2.20), after this yesterday I've managed to install an update that failed, failed because of Windows why others download and install and these aren't? then.. again microsoft thinks I need a ADVANCED MICRO MEDIA 30/11 something labeled as "DISPLAY" driver, I don't microsoft no i dont.. if you wanna invent microsoft basic adapter display i'll sure buy that gpu, ahaha! Currently taking any safety measure of unnecessary registry changes by using portable browser and now I pay monthly for Kaspersky Anti Virus, yesterday I've also ran an offline scan of KRD didn't found anything, my main issue tbh what I saw is similar to someone who doesn't know how to take antibiotics, at some point you gonna eat yourself and so this is what happens to my PC. Windows Defender detected itself as some form of virus causing also a BSOD because of that high disk usage/cpu anti malware something ahaha
