consumption psu watt on overclock
veteranos
16
hello i started build a pc and i wonder when il need to overclock my system my psu will manage
to control?
System spec:
ZALMAN z11
ASROCK 990FX EXTREME3 RETAIL
AMD FX-8320 3.5GHZ 8-CORE BOX
MSI Radeon R9 270X 2GB Hawk
CORSAIR CML16GX3M2A1600C10 VENGEANCE LP 16GB (2X8GB) PC3-12800 DUAL CHANNEL KIT
XFX XTR SERIES 650W PSU
ZALMAN CNPS9900 MAX RED FAN
5 FAN
1TB SEAGATE
Yes, it's really good. XFX PSUs are made by Seasonic, which is one of the best PSU manufacturers in the world.
On a completely different note: If you are not editing videos/rendering, you don't need more than 8Gb of RAM.
you suggest that to go for 8gb ram . i've just add that memmory bcz its compatible with mobos of the build that i searched im too nervous aout the compatibility you have any suggestion about a ram to tell ?
What is your motherboard?
Sorry, I like to keep things strictly business, I hope you understand :)
on the list of memmory size i can pick a 4gb brand and pick 2 sticks for 2x4 = 8? the memmory you propose on the list have kingston with the a /4g the one you propose is /8g what difrence?
Model KHX1600C9D3K2/8G
the one you propose and the list on example
KHX2133C9AD3X2K2/4GX
That's actually two 2 GB sticks, and it's pretty expensive too: http://www.walmart.com/ip/Kingston-HyperX-Grey-Series-4GB-2-x-2GB-DDR3-SDRAM-2133-240-Pin-Desktop-Memory-Model/15747235
It's faster, but it really doesn't matter; You won't see the difference while gaming.
