Question Continuous beeps with ram in 2nd slot! Help pls !!!
Dec 27, 2020
I have a Gigabyte H81m-d2v motherboard , after changing thermal path , and if I insert a ram stick into the first slot closest to the cpu socket with nothing in the second slot, it will boot up and run fine. However, since I have 2 ram sticks, if I put one in the second slot, I will get continuous beeps and restarting pc . Please help.
Ralston18
Update your post to include full system hardware specs and OS information.
Check the motherboard's User Manual.
Some motherboards require that the first installed RAM module be installed in a specific slot.
Verify (again via the motherboard's User Manual) that you are using supported RAM.
Most likely the User Manual will refer you to Gigabyte's website for updated information via the QVL (Qualified Vendor's List).
Also: are the two RAM modules from a matched set for dual channel use?
