G
Guest
Guest
Archived from groups: rec.games.trading-cards.magic.rules (More info?)
When an effect allows you to take control of an enemy creature (for
example: The Callous Oppressor ability "{T}: Gain control of target
creature that isn't of the chosen type as long as Callous Oppressor
remains tapped.") will the creature still be tapped when I take control if
it was already tapped when I grabbed it?
A concrete example: An opponent declares an attack and assigns an elf and
a snake to attack me. I use the Callous Oppressor to take control of the
elf prior to the assign blockers step.
Do I get the elf tapped? (It would be really handy to use it to block his
snake...)
Of *course* the creature comes to me summoning sick... It's just that it
has been argued that the tapped state of the creature won't apply by some
folks I play with... since the creature is "freshly summoned".
Gene P.
Slidell LA
Alcore Nilth - The Mad Alchemist of Gevbeck
alcore@uurth.com
snake...)
Gene P.
Slidell LA
alcore@uurth.com
