[SOLVED] Control Case Fans in Bios?
Dec 13, 2020
14
Hey, I just finished my PC and got it started and everything. I wanted to see if i could control the fans that come with my case but in bios it just says 0RPM. Is it not possible to change the speed of them?
I have an: Msi B450M-A PRO MAX
Case: Aero Duo one
I put all the fans in the little HUB you get with the case and installed everything as it says in manual.
Thanks!
u will need to change in bios fan mode to PWM
that header doesnt have cable for fan speed so u wont see any RPM there, but pwm works in percentage, so if u set pwm 60% fan will run at 60% as long as fan(s) doesnt die, u should be fine, as bios/software wont know if u have fan failure or not :/
