Control case fans with Corsair Link
james_911
6
Hi, i bought a H100i GTX and to control it i installed Corsair Link; i can control the H100i with no problem but i'm here to ask if is possible to control also the 3 case fans (corsair vengeance c70) that i have with the same software.
Now i have to use corsair link for the H100i and SIV (gigabyte mobo) for the case fans. I would like to use only one software for checking the temps and for control all the fans speed.
Thanks.
Can you please pass on your full systems specs? As far as Corsair have stated, their Link Dashboard software can take advantage of your motherboard's fan controlling ability alongside monitoring other i suffixed product's from Corsair. That is a little misleading since I know that you require a Corsair Link module to have the rest of your fans monitored and controlled off one software/utility. Read more here.
That being said, there's no harm in experimenting. If you've followed through the manual for the installation of your cooler you should be connected tot eh motherboard via the USB cable running from your H100i. You can then download the software off your product's download section alongside the Corsair's Link Dashboard manual.
Lastly here's the download url for the software.
