Control + D won't work in CSGO
SBennett13
363
I'm currently experiencing a weird malfunction with my computer. My left crtl and d keys only both work if the d is pressed before left control.
In Counter Strike, if i move to the right (d) and then crouch (left ctrl), then both keys function as they should. If I first press left ctrl to crouch and then d to start moving (so my movement is crouched from the beginning), then only the left ctrl key registers, resulting in me couching while not moving.
These are the specs of my PC:
i7-4790k
GigaByte Z97X-Gaming 7 rev 1.0 (F8 Bios <- latest)
EVGA GTX 980 FTW GPU
Finalmouse2015
Corsair K70 RGB (latest firmware, updated CUE) <-- Has n-key rollover.
Windows 10 Pro
I'm open to any suggestions to try, as I have tried everything I can think of including:
Using only 1 USB connector into the USB 3.0 port
Using both connectors in USB 2.0 ports
Rebinding the key in CUE and CSGO
Flushing Steam Config
Deleting 'Bags' Key from Registry.
ALL HELP APPRECIATED.
Same thing happens with my old keyboard. This issue is the main reason I got a new keyboard, because I thought the other one was malfunctioning. Current keyboard has n-key rollover and old one had 21 key rollover.
I don't use any macros. My auto execute file automatically runs when the game is launched which includes unbinding every key and rebinding the keys.
I did say to revert them to default... Check your script, you might have accidentally put ctrl+d in there somewhere.
If those are the only binds you have outside default, there may be some sort of keyboard filter running . Check the sticky keys settings to make sure they are off, and after that posting the details tab of the task manager might be necessary to spot software that might be acting as a filter.
I've been experiencing this same problem.
I haven't tried CS:GO. I've only observed this is in CS1.6. But it's cost me and/or my teammates our lives and/or the match , MANY times.
My specs are
Windows 10 Basic/Home 64-bit
i5-2500k
Z77 EXTREME4
8GB Corsair
EVGA 970
Corsair K60 (had n-key, until this)
It seems to have started at the time Microsoft rolled out the latest W10 update.
It also has severely crippled my SoundBlaster X-fi. I can't even get SoundBlaster driver installer to SEE my X-fi is present...
Which makes me think this is something on the backend MS has done.
