Hey all,
So I've been dealing with this issues for almost a week now. Have spent hours trying to figure out what the issue is. Control panel wont load right away, it takes about 5 to 10 minutes or even 30 minutes to load and it just sits there in a blank page and wont let me exit as well. After it finally loads and it opens, all the programs inside control panel open just fine except for Windows Firewall. When I click to open windows firewall it also take a few minutes to load and open. All other programs open up just fine except for firewall. EA Origin is another program that does not load but this one takes some up to an hour or 2 to load. And finally the other program that doesn't work is the setting option when you swipe your mouse to the right to bring up the windows 8 options menu. The settings menu will take a long time to load its options. I was having an issues with my sound service not running so I decided to use tweaking.com "windows repair" So I ran the program and it solved the "no audio service running" problem. After I did this I started getting the issues that I am talking about. Please help as I am on the brink of factory reset and I do not want to do that. Thanks!
