Question Controlling 2-pin fans with fan controller ?
Nov 17, 2020
Hello,
I have some great 2-pin fans (8 of them) that I want to use in my case but they are very loud at 100% speed. Can I use any controller to lower the fan speed to 90% ?
They have 2-pin female connectors.
Thanks
You salvaged them from PSU's, now didn't you? If so, they're only good for the PSU's they came from since the fan profile is bespoke to that fan and the unit it came from. You can shoot us an image of the fans(stickered information and the connector) and we can confirm that for you.
Reactions: MasterSipo
Hello, thanks for the answer. No, I got them with my mining server case. This is the fan
https://www.google.com/search?clien...hUKEwjczLiYi4ntAhUL-qQKHcgxAgMQ4dUDCAw&uact=5
I do not have the image of the connector now, but it goes to this male connector as on this image (black)
Fan_4-Pin_PWM_Connector_Male_to_2-Pin_CB-32D_Connector_Female_%285cm%29_%281%29__92125_zoom.jpg
Thanks for the reply.
this are my connectors.
if I would to buy molex fan controller, the next problem is I only have pcie 6/8pin power connectors on my psu and this small 2pin connector. How do I power on the controller ?
