Hi there, recently I bought a ID Cooling PL12025 4-pin PWM. I installed it on molex first and its noisy running @ 2400 RPM. I transferred it to my Motherboard CHA_FAN 3 pin but It's just the same. I've read some forums that you need to adjust the fan's voltage from 12V to 5V via BIOS. But it seems I can't find it on my BIOS.
So is there any way that I can control my fan?
Or if I would buy a Fan controller (Deepcool Rockman PWM for cheaper fan controller) and connect it to my 3 pin mobo, would that be possible? Thank you!
