Hi, I have a 3 pin header called CHA_FAN on the mobo in which i have a 3 pin fan connected, no PWMs involved. This fan is going on 100% rpm all the time.
The Cool'n'quiet function in the BIOS only allows for the control of the CPU fan, not the chassis fan.
For some ASUS mobo's there is a Chassis Q-Fan control option in the BIOS just below the CPU fan control, does this mean my BIOS is too old and i should update or does it mean my mobo just doesn't support that function?
Also, according to some people, even 3 pin conectors should be able to control the fan speed through voltage control mode, but i was unable to find out if my motherboard supports this.
If possible I want to avoid buying a fan controller or adapter to lower the voltage. I have tried SpeedFan, but that didn't work.
Thank you for your time
