xzqt23 Jun 3, 2021 2 2 10 Jun 3, 2021 #1 How do I convert RAW drive to NTFS without losing data, I tried to recover it using recovery software but it didn't work.
Solution H H hotaru.hino Jun 3, 2021 Many moons ago I used a tool called TestDisk to fix a partition that suddenly showed up as RAW.
H hotaru.hino Glorious Sep 1, 2020 9,805 3,567 46,090 Jun 3, 2021 Solution #2 Many moons ago I used a tool called TestDisk to fix a partition that suddenly showed up as RAW. Reactions: xzqt23 Upvote 0 Downvote Solution
USAFRet Titan Moderator Mar 16, 2013 179,640 22,158 184,590 Jun 3, 2021 #3 xzqt23 said: without losing data Click to expand... Why is it now appearing as RAW? Where is the backup of this data? Upvote 0 Downvote
xzqt23 Jun 3, 2021 2 2 10 Jun 4, 2021 #4 hotaru.hino said: Many moons ago I used a tool called TestDisk to fix a partition that suddenly showed up as RAW. Click to expand... Thank you it worked. I was able to recover data from a corrupted HDD of laptop. Reactions: AMY09890 and hotaru.hino Upvote 0 Downvote
