junkeymonkey :
the rant is if he looked befor he leaped he would of see this coming .
all right there to see and understand in the cards reviews .. see you pay 100$ 400 for a card that cant do 1/2 of what the 100- 400$ card from the last series can do out of the box native
get it ???? .lol...... now add that crazy adaptor to that cost or a new monitor to enjoy your new 1/2 butt card , right ???
sorry the truth hurts , but good luck
I'm sorry to have to say it, but you are not sounding too good in this discussion. Analogue outputs have been on the decline for generations, both as inputs and outputs, it's cost for functionality that very very few people use nowadays, analogue on a digital display is not clear and crisp, so get rid of it.
The 1050ti has better performance than the 950, not sure where the 1/2 capability comes from, unless you are talking about the analogue outputs being 1/2 of it's capability, gut feel maybe 1-2% of the PC population are using analogue monitors now, so that 98%.
Can I suggest that you take a nice long look at what you are about to post, and see if it makes you look more or less foolish, and then edit it to go down the less foolish path.
As to Seyed, going from digitial to analogue will always have some loss in image quality, in a gpu you would ideally want to go from digital (inside the GPU), and maintain that digital path all the way to each individual pixel. What you are going to do is take a digital signal, approximate it with an analogue one, and approximate the original digital signal once inside the monitor. They all work the same though, no one is investing in the 'best' solution to this, it'll be a bit blurrier.
